NEC 2690WUXI2 ghosting
I have a NEC 2690WUXI2 but there is very significant ghosting, even larger than my old NEC that has a larger response time. Is this a common problem, or does it have a known solution?
Have you enabled overdrive? I think it's called rapid response in newer NECs.
Go into the advanced settings by pressing input and on/off button at the same time.
