NEC 2690: more input lag when using monitors scaling?
Frameless
Just purchased my second NEC 2690wuxi (other one got returned for severeal reasons) and i noticed something very strange. In the Nvidia control panel, i switched from monitor scaling to Nvidia scaling with a noticeable improvement in input lag. I can't do any test, but i can really feel the mouse being more responsive in windows, and in FPS it's not even a question that there is an improvement. I have vsync off and the monitor runs at native resolution 1920x1200.
Why is this? Shouldn't it be the opposite, with Nvidia scaling introducing more input lag? Well, I'm very happy with the monitor now, as the input lag doesn't bother me that much anymore. Before it was horribly sluggish.
Did a few test with the monitors overdrive too, and man does it make a difference. Seriously, when you turn on the monitors overdrive, the blur literally disappears. This screen is so awesome, watched some blu-ray movies last night, simply amazing. :)
Monitor electronics are ALWAYS slower than GPU. OTOH, GPU scaling tends to be blurry and just not as crisp as a native solution (monitor's scalar).
Though, I'd probably consider only GPU scaling for your monitor, 2+ frames is not ideal for gaming at all.
But the monitor is running at native resolution, so there shouldn't be any work with scaling from the monitor, right? I find it strange that i haven't read about this before, as I've researched monitors and the technology a lot the last few months.
Probably there are different implementations for scaling.
Internal scaling of NEC is apparently one of the best quality ones so that could be one factor.
And beside pure speed difference also its scaler might wait for full frame to be buffered until interpolating image to native resolution while other method (possibly used by graphic card) would be starting to calculate interpolated image when only something like half dozen lines are ready meaning interpolation would be practically lag free.
Before any answer is accepted, you need to clarify for yourself and the others - what do you call monitor scaling and what (and how) do you use it for.
Really this sounds like the placebo effect to me. You are at native resolution, no scaling anywhere in either case.
With my 2490(presumably same electronics), I measured it against a CRT, NVidia Scaling was off, I got the standard 32ms average lag. (I saw 16ms, 32ms, and 48ms lags, but mostly 32ms)
I also did a brief measurement with overdrive on. This did seem to increase lag for me by a small amount. Enough that I occasionally was getting 64ms lag frames. I also didn't notice any real benefit to having overdrive on. It looked pretty much the same either way (which is pretty good for LCD), so I left it off.
Show me the measurements first then I will be interested in your subjective feelings about it. As it stands this could simply be placebo.
Here is my report on the 2490 response:
http://www.hardforum.com/showpost.php?p=1032929430&postcount=2
It is not strange, when monitor scaling is turned on, the input lag is always higher. But as I use the scaling only with strategy games or other older games, I do not mind. The monitor scaling is a way better then the one which nVidia provides.
Well it is very strange indeed, if, as stated above, you are running at native resolution.
What happens you turn on graphics card scaling at a lower resolution, is the card scales say from 1680x1050 to1920x1200, the monitor receives 1920x1200, so it has no scaling work to do, if card scaling was off, it would receive the lower resolution and has scaling work to do and conceivably this could add to lag.
If you are running 1920x1200, Video card scaling on/off should make no difference, it will send 1920 to the monitor and the monitor will have nothing to do.
