NEC 2490WUXi....... Been checking out the measurements with stand to see if it will fit on my desk.It says it's 22.9" high is that with the stand in it's lowest position and it says it's 12" deep. Is that from the back leg to the front of the panel? The width says 21.8 X 17,what does that mean? Can you still get the earlier version with the polarize panel and calbrator. If so what is the model #. Thanks
