As a graphic designer I need good colour reproduction and I will also be playing my xbox 360 on it.
hmm.... I was leaning towards the Dell but I heard it has minimal ghosting...also did they fix the banding issue?
This is such a hard decision...
Really? but its a gaming monitor ... doesn't it have apect ratio control (1:1 pixel mapping)
What about the Dell 2007WFP? Is that XBox360 friendly? I'm never going to find the right monitor...![]()
Anyways my contenders are:
-Dell 2007WFP
-NEC 20WGX2 or 20WMGX2
-Viewsonic VX2025WM
Any Xbox 360 owners with one of this monitors..... would love your input.
If you are planning to use the new monitor for your 360, the 20WMGX2 has some significant issues with the non-dvi inputs. There are some scaling issues with 480p/720p/1080i over component, and VGA has issues with scaling as well. An xbox630 hooked up via the VGA cable, for example, will stretch the 16:9 720p image to fit the 16:10 NEC 20WMGX2.
