This is my first lcd. I knew before i bought it that lcd's are badly flawed but this display is actually even worse than i expected. The input lag is very annoying and i also hate having to use 60hz wich is just not anough at all, i hope they make 120hz displays soon and fix the input lag problem since this is just a temporary monitor and im planning a new one in 18 months. These are problems i had expected, what i didnt expect are the very bad viewing angles and the noise across the whole screen. The contrast changes dramatically when only looking at a slight angle and on blacks i can see a yellow and purple glow, the most obvious being the yellow/gold glow in the bottom corners of the screen on this site.
The noise problem is very annoying too, it just came to me this might be a 6bit panel with dithering? But even if it isnt and this is caused by something else then what is the point of 8bit if the lcd's are this noisy anyways. I can also see some brightness variations across the screen, i dont know if this is a backlight problem or something in the panel?
Anyways i am wondering if all this is normal and what others think about it?
Since i havent read anything about this noise pattern and the yellow and purple glow on ips, and im very surprised about the crappy viewangles.
