ND-3550A And Nero 7
chrisfnet
I can't seem to get my drive to burn any cds this evening. Here is the log:
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 11/2/2004 1:54:32 PM
NT-SPTI used
Nero Version: 7.0.0.0
Recorder: <_NEC DVD_RW ND-3550A> Version: 1.05 - HA 1 TA 0 - 7.0.0.0
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <_NEC DVD_RW ND-3550A >Version: 1.05 - HA 1 TA 0 - 7.0.0.0
=== Scsi-Device-Map ===
DiskPeripheral : WDC WD1200BB-00CAA0 nvata Port 0 ID 0 DMA: Off
CdRomPeripheral : _NEC DVD_RW ND-3550A nvata Port 0 ID 2 DMA: Off
CdRomPeripheral : SCSIVAX DVD/CD-ROM 2.7a vax347s Port 3 ID 0 DMA: Off
=== CDRom-Device-Map ===
_NEC DVD_RW ND-3550A D: CDRom0
SCSIVAX DVD/CD-ROM E: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 2047MB (2096616kB)
Free physical memory: 1513MB (1550224kB)
Memory in use : 26 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
25.2.2006
CD Image
7:42:29 PM #1 Text 0 File ThreadedTransfer.cpp, Line 525
ReadBuffer-Pipe got 81920KB of Memory
7:42:29 PM #2 Text 0 File Reader.cpp, Line 124
Reader running
7:42:29 PM #3 Text 0 File Writer.cpp, Line 113
Writer D: _NEC DVD_RW ND-3550A running
7:42:29 PM #4 Text 0 File Burncd.cpp, Line 3301
Turn on Track-At-Once, using CD-R/RW media
7:42:29 PM #5 Text 0 File DlgWaitCD.cpp, Line 277
Last possible write address on media: 359845 ( 79:59.70)
Last address to be written: 314891 ( 70:00.41)
7:42:29 PM #6 Text 0 File DlgWaitCD.cpp, Line 289
Write in overburning mode: NO (enabled: CD)
7:42:29 PM #7 Text 0 File DlgWaitCD.cpp, Line 2568
Recorder: _NEC DVD_RW ND-3550A
7:42:29 PM #8 Text 0 File DlgWaitCD.cpp, Line 456
>>> Protocol of DlgWaitCD activities: <<<
7:42:29 PM #9 Text 0 File ThreadedTransferInterface.cpp, Line 846
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (2 - CD-ROM Mode 1, Joliet)
2 indices, index0 (150) not provided
original disc pos #0 + 314892 (314892) = #314892/69:58.42
relocatable, disc pos for caching/writing not required/not required, patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 314890 blocks [D: _NEC DVD_RW ND-3550A]
7:42:29 PM #10 Text 0 File ThreadedTransferInterface.cpp, Line 1058
Prepare recorder [D: _NEC DVD_RW ND-3550A] for write in TAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 645206016, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
-150 | lead-in | 0 | 0x41 | 0x00
-150 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
314892 | lead-out | 1 | 0x41 | 0x00
7:42:29 PM #11 Text 0 File ThreadedTransferInterface.cpp, Line 1126
Removed 2 run-out blocks from end of track 1. Length: 314892 -> 314890.
7:42:29 PM #12 Text 0 File SCSIPassThrough.cpp, Line 34
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
7:42:29 PM #13 Phase 24 File dlgbrnst.cpp, Line 1724
Caching of files started
7:42:29 PM #14 Text 0 File Burncd.cpp, Line 4129
Cache writing successful.
7:42:29 PM #15 Phase 25 File dlgbrnst.cpp, Line 1724
Caching of files completed
7:42:29 PM #16 Phase 36 File dlgbrnst.cpp, Line 1724
Burn process started at 48x (7,200 KB/s)
7:42:29 PM #17 SPTI -1189 File SCSIPassThrough.cpp, Line 306
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1189)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x30
Sense Qual: 0x02
CDB Data: 0xAD 00 00 00 00 00 00 FF 40 00 00 00
Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 30 02
Buffer x03825200: Len x4000
7:42:29 PM #18 Text 0 File ThreadedTransferInterface.cpp, Line 2669
Verifying disc position of item 0 (relocatable, no disc pos, patch infos, orig at #0): write at #0
7:42:29 PM #19 Text 0 File MMC.cpp, Line 21541
Set BUFE: Buffer underrun protection -> OFF
7:43:05 PM #20 SPTI -1135 File SCSIPassThrough.cpp, Line 306
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1135)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 00 00 00 02 A0 00 00 20 00 00 00
Sense Area: 0x70 00 03 FF FF FF 6A 0A 00 00 00 00 0C
Buffer x033b0000: Len x10000
0x30 C7 F3 96 59 28 A4 41 3B 31 60 4F 48 65 25 11
0xE4 5A 7F 09 CB D2 43 7F 9F D1 73 61 0D F2 7E 12
0xA0 4E F1 CF 80 70 56 7F F8 72 50 7C 4A 96 C2 C7
7:43:05 PM #21 CDR -1135 File Writer.cpp, Line 302
Write error
7:43:05 PM #22 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
7:43:05 PM #23 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
7:43:05 PM #24 CDR -201 File WriterStatus.cpp, Line 200
Invalid write state
7:43:05 PM #25 TRANSFER -18 File WriterStatus.cpp, Line 200
Could not perform EndTrack
7:43:05 PM #26 Text 0 File MMC.cpp, Line 16273
<_NEC DVD_RW ND-3550A > start Close Session
7:43:05 PM #27 SPTI -1176 File SCSIPassThrough.cpp, Line 306
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1176)
Sense Code: 0x72
Sense Qual: 0x04
CDB Data: 0x5B 01 02 00 00 00 00 00 00 00 00 00
Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 72 04
7:43:05 PM #28 CDR -1176 File WriterStatus.cpp, Line 249
Session fixation error
7:43:05 PM #29 TRANSFER -19 File WriterStatus.cpp, Line 249
Could not perform Fixation
7:43:05 PM #30 Text 0 File WriterStatus.cpp, Line 258
falling back to disc fixation
7:43:05 PM #31 Phase 38 File dlgbrnst.cpp, Line 1724
Burn process failed at 48x (7,200 KB/s)
Existing drivers:
File 'Drivers\CDRALW2K.SYS': Ver=6.0.0.171 , size=24839 bytes, created 1/13/2003 10:19:26 AM
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Any ideas? :confused:
I have no idea, but this belongs in the optical forum. Or you can try posting on cdfreaks.com.
