Feb 18, 2006 #1 S stopmenow Limp Gawd Joined Jan 1, 2006 Messages 464 how do i enable/disable it on windows?
Feb 19, 2006 #2 Z Zorn Limp Gawd 2FA Joined Aug 22, 2005 Messages 452 I'm also curious about this since anandtech mentioned a 9% performance boost with NCQ disabled on the 150 Raptor.
Feb 19, 2006 #3 Zardoz 2[H]4U Joined Aug 27, 2000 Messages 3,251 If you go to device manager and look up your IDE controllers when you drill down to a drive you will see a enable check box. most likely it's already on...
