Hello,
I am planning to build my next desktop with this awesome case.
Config:
Case: NCASE M1 v3 Black (With ODD)
Power Supply: Silverstone SX500-LG
PSU Cables: Silverstone PP05-E
CPU Cooler: Corsair H105
CPU Cooler mounting: Asetek Narrow ILM LGA2011 kit
Fans: Noctua NF-F12 PWM x 2
Motherboard: ASRock X99E-ITX/ac
Processor: Intel Core i7 5820K
Memory: Corsair Vengeance LPX 16G (2*8G) DDR4 2400Mhz
Graphics Card: Asus GTX 670 (GTX670-DC2T-2GD5)
Hard Disk: Samsung 840 Pro
Optical Drive: Panasonic UJ-265 Blu-Ray/DVD/CD Writer
Operating System: Funtoo (like Gentoo Linux)
Miscellaneous: PCI 3.0 x16 Shielded riser ribbon (5cm)
Goal:
Main desktop plugged on the main flat screen.
Compact.
Powerful.
Workstation.
Gaming/Compiling.
Reasonably Quiet.
No overclocking.
It will replace my old rig:
Notes:
For the cooling part, I am planning to use the riser to put the graphic card lower to help it to get cool air from outside, it will also help with the PSU cables...
And I will replace the corsair fan of the water-cooling with noctua one and put them in exhaust push.
I know this is not the best way to go as I will make CPU hotter but it will help with the pipe kinking issue as the radiator will be as far as possible from the cpu and I fear that the case will be too hot inside without an active exhaust system.
I will buy a NVMe M.2 superfast ssd to replace the Samsung one (not released yet), maybe upgrade the GPU/CPU in the next years, if needed replace the PSU with new 80+ platinum SFX-L from silverstone (so sad it is not out yet...)
Any comments are welcome
Config:
Goal:
Compact.
Powerful.
Workstation.
Gaming/Compiling.
Reasonably Quiet.
No overclocking.
Notes:
