Ncase M1 Dual 240Rad Help
{NG}Fidel
So currently I am running an Ncase as my main Gaming Rig. The Show-off Rig so to speak.
I have a titan X Pascal that is in RMA at the moment but I want to build out a WC loop for the CPU/Board, and GPU. If a single 240RAD is enough to maintain my clocks then thats fine but I was honestly thinking a 120 for the GPU and a 240 for the CPU/Board. Hard Tubing would be something I would like to try but I will opt for soft tubing if need be.
Rig is in Sig.
Pretty easy. I was rubbing a 5820k and 1070 in my Ncase with 120 + 240 rad with pump and reservoir internally. Let me see if I can dig up some pics for you.
I'm also interested in these pics if you can find them.
Thanks!
240 + 120 aqua computer airplex radiators
