Greetings! I am a first-time builder and first-time poster. I would be grateful if someone would please look at my intended build to confirm that it should work. Have I done anything obviously wrong? I have answered the questions from the Sticky Post below. If you bother to read through it all, you are heroic.
Thank you very much,
Charlotte
CASE: NCASE M1
Motherboard: Asus P8Z77-I Deluxe $137.99 link
CPU: Intel Core i5-3570K $219.99 (or i5-3550 if price is much lower) link
GPU: NVidia GTX 760 by MSI $259.99 link
PSU: Silverstone SFX 450W $93.99 link
RAM: 2 x Corsair 8GB 1600mhz DDR3 $79.32 link ?
SSD: Samsung 840 Pro 256GB $224.95 link
Cooling: I think case comes with fans? If not, I will buy 2x120mm fans?
Optical DVD: External USB DVD $35.78 link ?
Monitor: 24 inch 1920x1080 $147.99 link ?
OS: Win 7 Home Prem.. Owned (new box, unopened)
TOTAL: $1200
Answers to sticky post questions:
1. Use: Portable Gaming - mmoRPGs and solo RPGS - GW2, Neverwinter, Secret World, WoW, Skyrim etc. Currently using a 5 year old ASUS gaming laptop that runs these games on lowest settings, so a mid-range gaming computer for casual gaming will feel like an incredible upgrade to me.
2. Overclocking? No Water cooling? No. Way too intimidating and complex for my first build.
3. Budget: Less than $1500. Preferably closer to $1000. I am aiming for mid-range gaming. Less is better if it doesn’t sacrifice performance much.
4. Do I live near box stores: No. Am in USA. There is one Best Buy near me, nothing else. I plan to use mostly amazon prime.
5. What exact parts do you need? I listed everything I plan to use above. That is the full build. I feel pretty good about most of the parts. I’m still uncertain about:
7. Specific features needed: Portable! I take my compy to game with my best friend 2x per week.
8. Resolution: 1920 x 1080 seems fine.
9. Space and optical drive: No particular space limit, am trying to go as small and light as possible for portability. Optical drive - see #5.
10. Case modification: No, please.
11. Noise: Quiet is nice but ranks lower than portability, performance and price.
12. Mobility: Highest priority. Small and light weight are important. Plan to use GearGrips harness and a cover that I will sew myself to provide cushioned protection and carrying capacity for extras (keyboard, power cord, headphones).
13. OS license: I own a new, unopened, legit Windows 7 home prem labeled as OEM system builder pack.
14. When do you plan on building/buying: As soon as my M1 case arrives in January. Will start to buy parts now if they hit a great price point.
edit: Fixed broken links. My apologies, I didn't realize that the tinyurls wouldn't work.
Charlotte
CASE: NCASE M1
TOTAL: $1200
Fans - Do I need to buy them or do they come stock? I’ve assumed they ship with the case. If not, I think I need 2x120mm fans mounted to case bottom? They should blow air into the case?
GPU - NCase page recommends a rear exhaust GPU. Does this matter hugely? Should I get this card instead?
Optical drive - Does the case only take an internal vertical slim optical drive? Those seem rare and expensive. Is there another internal type I can use? I plan to use DVD not blue-ray, to keep price down. I don’t use a DVD drive very often. Rarely to watch a video or load a game. Currently plan to use an external USB OD as that seems low cost and good enough.
Motherboard: Some commenters report that a video card requiring dual slot blocks the HD audio connection on this MoBo. I think that means I wouldn’t be able to use the microphone and headphone jacks at the front of the case? I use microphone and headphone jacks frequently for gaming, so using the front ports would be ideal but, my current plan is to use extension cords from the rear mobo ports if needed.
Monitor: Still researching. 23” or 24”, 1920 x 1080 seems likely.
6. Reused parts: NoneGPU - NCase page recommends a rear exhaust GPU. Does this matter hugely? Should I get this card instead?
