NB, SB, and PCI-e blocks needed
rjolin01
I have a MSI P7N SLI-Fi mobo and want to watercool at least the NB. I dont really need waterblocks for SB and pci-e though. and if not water cool the SB and PCI-e componets I need to find good heatsinks with fans. I am having trouble figuring out and locating these componets. Please help.:confused:
Post some more info about your pci express components - do you mean graphics cards? Usually you do not need to water cool the SB, but you will need a heatsink & fan at least. You should definetly get some heatsinks for the mosfets if you plan on overclocking. Sorry I am not familiar with that motherboard but a general NB cooler like the swiftech mcw30 may work. Check out some of the more popular online water cooling shops like petrastechshop.com, frozencpu.com, jab-tech.com, performance-pcs.com, sidewindercomputers.com, etc. This really should of been put in the watercooling forum, but start at those shops. If this is your first time water cooling, I suggest you hit up the liquid cooling subforum under overclocking & cooling to get you started right.
Im using a DD MCP Universal on my DFI board witha sexy brass top for added security. you can email DD and see if it will fit (it fits most MB's)
the pci-e i am talking about is the chipset that is inbetween 2 of the pci-e slots. my mobo has 3 chipset coolers all bridged together to pretty much make it one heatsink. if i take off the nb to h2o it i will either need to cut (which i dont really wanna do) the connecting heatpipe or replace the sb and pci-e chipset with separated heat sinks. as for the nb cooler i have a swiftech cooler i was using on my old mobo but on this one holes to far apart. but i believe i found the coolers i am going to use. 2 enzotech slf-1 for the sb and pci-e chipset and a koolance gpu-200 for nb. now only thing is that this may sound stupid but ihow i figure where the mosfet is? mine dont have a cooler on it but thought maybe should add one if oc'ing.
First of all, cutting the heatpipe would make the whole thing trash, don't do that. As for the block choices, I personally am not a fan of koolance as they are known to use aluminum in their blocks, and mixing aluminum and copper in one loop, even with corrosion inhibitors, is a bad idea. I'm thinking those two lower chips might be fine with a low profile heatsink and fan like the evercool vga one.The mosfets are the small black chips around two sides of the cpu socket, with most of them on the side towards the rear i/o panel. You will need to use some basic heatsinks with thermal tape on these, as there doesn't seem to be mounting holes for blocks (which are a waste in most cases anyhow). I recommend making a new thread in the watercooling subforum, and list out all the parts of your loop including these blocks you are thinking of and see what people have to say. Your mobo uses the 750 sli chipset, be sure to include that with your motherboard information in the post.
