Power sources are going to become a major concern for naval operation and war soon too. With these new technologies that require HUGE amounts of power we and other nations are going to build ships with HUGE reactors. Crazy stuff
For a laser, that's very impressive. For a ship mounted weapon, that's pitiful.
seems an expensive boat to set ablaze just to prove you can in this economic times...
shield everything with mirrors problem?
Mirrored surfaces aren't a big problem, they either shoot at a place without them, or employ more destructive physical munitions.
Power isn't going to be a major concern. You simply need capacitors. You're just stuck having to charge the weapons. Then you have your regular bullet, missiles, etc for quick reaction.
A chromed out ship sounds like big pimpin'!shield everything with mirrors
problem?
I think it was more 'proof of concept' than a demo. They likely want to get the optics and targeting right before they ramp up the power. First things first, you know... dont need to blow a hole in their own ship by accident because they didn't adjust something just right.
Yeah...
100kw laser vs 2x150 megawatt nuclear reactors on a destroyer.
Not seeing a problem here.
Time to think outside the box.I'm glad we still have money for stupid shit while American's starve and languish unemployed.
Most likely a boat seized under drug trafficking laws.
Still, It would have been nicer to give that boat to the border patrol or Homeland Security for their duties and use an old boat for this test. It's a bit wasteful to completely wreck this nice of a boat. They'll probably buy another, for four time as much at taxpayer's expense later.
THOSE WERE Mercury 200 horse outboards! Don't does idiots have any idea what those engines cost!!!!
They are about $12K each!!!
I almost puked when I saw that.![]()
WTF? Those engines cost a fortune? couldnt they just put some gasoline on a raft in a tank and blow it up? or something else flamable?
I paid for that shit.. that pisses me off...
If a $6,000 boat will help in making sure this works and allows someones mom, dad, brother or sister to come home, I don't have a problem with that.
Everyone with non-stealth aircraft are going to get reamed when the aircraft versions of this that they are working on come out.
How about $5.2 billion in lost research? The USAF already made an airborne laser that could blow up missiles. Then they abandoned the project. So why the hell is the Navy starting from scratch, from what I can tell, is the same exact fucking project. Just that it's mounted on a ship, instead of a plane.
Well, there are two reasons I can think off of the top of my head. A. I wonder, if the lazer is hot enough to melt through 2000 ft of steel in a single second, I wonder how long the laser would take to melt 'glass' aka a mirror that's maybe 1/8th of an inch think? I suppose about 5 micro-seconds(not miliseconds) at which point the lazer is once again lighting your ship on fire. If you are extremely worried about the 5 microseconds of 'lazer' boucning back, you could attempt to aim it so the reflection is cast into the sea. IE at a cuved area of the ship's hull and make the ship start taking on water or target the same area and cut a horizontal line across seperate the top half of the boat from the bottom half. Alternatively, cut a reasonably large circle.
Secondly, a lazer can target/fire theoretically extremely fast. If you had a large mirror you were physically moving around the ship with 'motors' to try to avoid the lazer, well, there's the issue of it only last 5 micro seconds. Ignoring that, consider that a lazer can travel that 1 mile, considering its traveling at the speed of light, several orders of magnitude faster than your mirror can move via motors to protect that area of the ship and you'd only need to target an unprotect area of the ships hull for all of (1 mile / 186,282.397 miles per second) = 5.36 x 10^-6 seconds.
If you coated the ENITRE SHIP in mirrors, that would be fantastic except for the mirror lasting only 5 microseconds before being melted and the lazer going straight thru and the pointed out flaw of the ability to target areas of the ship were the hull is curved so the deflection is into the sea(not back at the navy ship firing the lazer). Not to mention the expense of covering entire ships in mirrors.
You really think they literally started from scratch? Really? ok.....
You do realize that glass responds to light differently than steel, right?
And please point out a ship that has a hull nearly a half mile thick.
Uh, yes. You obviously don't know the military and military contractors.
The US Office of Naval Research are the ones funding their little laser project. The USAF paid Boeing the money for their laser project. Do you think Boeing decided to just give all their research data to the Navy?
I'm not seeing how that's real useful. I was thinking it was like...instantaneously shot through. Like it burned a hole in the engines, then caught it on fire.
I can see this as being useful for killing ppl, not so much against vehicles. A weapon that has no recoil, no need for calculations of wind, distance, gravity, etc.
Umm...probably every single supercarrier has a hull of half a mile thick. Supertankers. The hull of the ship isn't a single sheet of metal, but it's the whole structure that sits in the water. The metal sheets themselves might only be 2-3 inches thick, but the hull can be half a mile thick. You're easily talking 2-3 ft of metal, if not more.
Not all of it but substantial amounts of the information gathered from those projects has become readily available. The Navy did not run a completely separate development project in a vacuum reinventing the wheel.
Also sorry for the ship detail. 1/4 mile. I don't have a clue how long these supercarriers are. Supertankers are close to 1/2 mile.
Yep, of course. The Navy obviously received some of the research data from the USAF. Hency why the Navy uses a completely different type of laser. How silly of me.
