Native LinSMP help!
nitrobass24
[H]ard|DCer of the Month - December 2009
Ok so i have installed ubuntu and have it working decent considering im still a linux n00b.
I used the finstall option by doing
Code:
curl -O http://ra.vendomar.ee/~ivo/finstall
chmod +x finstall
./finstall
Then i followed the prompts and entered my info.
I did not change any advanced options.
I then manually downloaded the new FAH6 drop in and replaced the current that finstall created.
But my the client wont start
Code:
stephen@stephen-desktop:~/foldingathome$ ./folding start
['folding' ver. 6.2]
Starting up FAH client(s) on 16 processor(s):
Starting FAH client at CPU1...
FAH client #1 startup: OK
Starting of FAH client(s): FAILURE
I've never installed fah on linux using those commands, where did you get those from? I always follow the linux guide in the sticky and it always works great for me.
Code:
chmod +x finstall
./finstall smp
Fixed ...... :p
you need to rerun Finstall with the SMP flag to intall the correct client.
Then drop in the new fah6.
Then open the FaH file and find the default flags line.
Change them to "-smp 16 -bigadv -verbosity 9" if you want to run with bigadv on 16 cores.
If you want it to run as a service its ./installService.
More info
Luck ............ :D
Fixed ...... :p
While I don't post that often, I do read quite often...I would just like to take a 2 minute timeout and point out the fact that Tigerbiten is the fucking man.
That is all.
Tru that. And you are puttin some nice points yourself bro
Posted via [H] Mobile Device
But now i noticed something weird?
In the memory to report it only shows i have 2MB available?
Code:
# SMP Client ##################################################################
                       Folding@Home Client Version 6.02
                          http://folding.stanford.edu
Launch directory: /home/stephen/foldingathome/CPU1
Executable: /home/stephen/foldingathome/CPU1/fah6
Arguments: -smp -configonly
[22:40:25] Configuring Folding@Home...
User name [Anonymous]? Nitrobass24
Team Number [0]? 33
Passkey []? 859e3bb111b2a087386d9157b552546f
Ask before fetching/sending work (no/yes) [no]?
Use proxy (yes/no) [no]?
Acceptable size of work assignment and work result packets (bigger units
 may have large memory demands) -- 'small' is <5MB, 'normal' is <10MB, and
 'big' is >10MB (small/normal/big) [normal]? big
Change advanced options (yes/no) [no]? yes
Core Priority (idle/low) [idle]?
Disable highly optimized assembly code (no/yes) [no]?
Interval, in minutes, between checkpoints (3-30) [15]?
Memory, in MB, to indicate (2 available) [2]?
Also it still gives me FAILURE when i start it.
ok well i have scrapped the finstall idea. and followed Xils guide in the sticky and have it running.
Now if I could HFM.net to run in linux I would be set.
