Ok, I have fixed this problem before by I am not sure whats wrong now. My azureus dowloads speeds are really low now. My comp set up on a router and my laptop is connected to it as well. I use a dsl modem. I do ipconfig, and im not sure which ip adress to use to forward. Is it the one that says ip address? Or is ith the default gateway, or subnet mask? dhcp server, dns server. Well i am tying to forward tcp and udp ports for azureus and i still get a nat error. I have windows firewall turned off. I thought a router kept my ip address the same and the ip address on my laptop is 101 while my comp ends with 100. Is there something i need to change in my router settings? And if so how do i do that? If you need any more information about my comp let me know please. I really want to solve this problem. Thanks
currently forwarded ip address from ipconfig ports 6881-6899 tcp and udp on both router and modem.
