- May 7, 2007
I'm kind of a noob in this area. Could someone please tell me the difference between a NAS and a SAN? I would really appreciate it.
this pic should explain everything http://en.wikipedia.org/wiki/Image:SANvsNAS.svg
What does that have to do with SAN? If you put NTFS on your SAN device you'll have the same problem, right?Try opening a large file on a Windows server with an internal RAID controller befor the file's done copying, either from the source, or the destination. You will get an error that the file is currently in use, and likely will have issues with the file transfer itself.
Could you clarify what the difference between these three parity schemes are? I'm especially curious about the difference between "raid 6" and "P+Q".SAN RAID devices can change RAID levels on the fly, grow LUNs, have global hot spares, and do levels of parity calculations (RAID 6...true RAID 6, not RAID-5 DP or P+Q) in order of magnitude better than add-in RAID controllers could ever hope for.
The "enterprise" sata drives are available on Newegg, too; here's a Seagate NS series disk for $240. I don't claim to understand economics, but the markup on disks in enterprise settings is fairly astounding.Disk drives for SAN enclosures are much more expensive than their desktop or NAS destined bretheren. I just spec'd an enclosure with 1TB SATA drives for a tiered storage array and the drives are $629/ea. You can get 1TB SATA drives on Newegg well under $200. The Enterprise class drives have been designed specifically for data center usage. Their MTBF is 1.4million hours or higher, usually. They have FDB bearings in the spindles, and tighter tolrances on the their mechanical manufacturing processes. Desktop drives are usually 500,000 hours MTBF, in comparison
Enclosures aren't always so expensive, though. The Dell MD1000 (I know, bad example) is $2500 empty, but 1TB disks for it cost $689. They're WD RE2-GPs, which cost $230 on Newegg. That's just the drive, nothing special that I can tell. But I'd bet they don't ship empty-but-usable rails with them.I can only answer the last question. He is referring to an ENCLOSURE + A 1TB Drive that cost $600. So the enclosure alone would be around $500 because it needs be either a fibre channel or support infiniband/mini SAS connection - the usual connection in high end enterprise stuff.
Sure, I know. Even though you could get close to equivalent density and reliability to SAS drives by buying three times as many sata disks and using three-way mirrors...Lastly, organization will only use so called "SATA Enterprise" drives in non-mission critical nearline backup situations. Nothing so far even your new SSD drives will replace true SAS drives in enterprise environment all due to enterprise drives having much better parity error tolerance.
True, but home users are using larger arrays than ever, and larger numbers of drives. It's only a matter of time before the demand for enterprise drives sinks down into the home user arena.Enterprise drives are not meant for home use anyways so the cost will not be a major concern for corporations.
Yes, enterprise can use three array system of SATA drives vs 1 array system of SAS drives but other factors starts to creep in - heat, space, power consumption and increase likelihood of drive failures. As a matter of fact, no SATA drives will touch enterprise sas arena. Event the new so called Velociraptor enterprise by WD will remain sketchy because they do not have a track record in making quality enterprise drives, whereby Seagate is the leader.
Enterprise drives will NEVER become widespread in the home because of economics and knowledge. A single 300GB SAS 15k.5 cost $500~600 and you need specialized controller to run it, which requires good knowledge of computer hardware. For example, most home users buy OEM computer from HP or dell. HP or dell will never put in a SAS controller in their home computer because of economics. You can go to the DIY route but not many home users have the knowledge. The average home user will simply not have the knowledge or money to use such drives. It might be different for enthusiast but they represent a minute market.
Sure I use a SAS drive in my workstation plus a 8 drive case SAS array because i have the need for such equipment due to the nature of work I do, but how many else would need that?
I think mage was talking about enterprise sata drives, not sas drives.
What do you mean by "the reverse order"? Are you talking about the parity generation scheme or the placement of the parity onto disks?The second stripe goes in the reverse order of RAID-5 (because that just makes sense).
Oh. Okay. I thought you might have been talking about NetApp's RAID-DP, which is significantly different from RAID 6 and should not be lumped in with it. If I've got this straight, what you call "RAID-6/DP/P+Q" is to RAID 6 what RAID 4 is to RAID 5.The other RAID-6 uses a differrent method of distributing the parity. It does it all on two drives.
All of the non-failed drives, including any parity disks that are left, are required to rebuild the data. Thus, all the drives "contribute" to the rebuild. The parity drives alone do not contain enough information to reconstruct a failed drive, (N-2) of an N-drive array are required.unlike the normal RAID-6 (above), RAID-6/DP/P+Q only has 2 physical drives (defined as the physical parity drives by the controller) from which it is recalculating the data on the lost drive. Instead of all drives in the array assisting in the rebuild, now there are only two.
this implementation will be in orders of magnitude slower than either true RAID-6, which is orders of magnitude slower than RAID-5./QUOTE]
I would be shocked and astounded if you could demonstrate even one order of magnitude difference between raid 5 and 6DP on the same physical set of disks. Even in base 2. Thirty or forty percent difference, sure. Not 900%.
I understand that. But my point is that home users will look at the IBM sales page, the Newegg page, and buy from Newegg. But if IBM had a cheaper-support option for home users, they might be able to get that business.To the poster that attempted to interpret my meaning when I said 1TB drives are $629 each from IBM...no...I really mean that just a single 1TB SATA drive, 7200RPM, that has an IBM sticker on it, and is qualified from anything starting at a DS320 to a DS4800 enclosure is $629 each...yes, 1 single 1TB drive. When it fails, you're calling IBM, and they're the ones replacing it for you, and usually within 4-8 hours. Try that with Newegg.
Yep. But the OP's question is answered, and there were some loose ends left open. I could have started another thread and asked there, but this one already had all the required context in it.I tihnk he went off on his own tangent, because almost none of it is directly related to the OPs thread.
Please, OP, if you'd rather I moved to another thread, let me know and I'll be glad to move.
On our SAN we actually use RAID 10. It provides better fault tolerance than RAID5 and even RAID6 in most cases and provides better write performance.
We use a 10 disk RAID10 with a hot spare. This system can suffer multiple drive failure as long as the right drives fail. Actually if all the right drives fail it can suffer a 5 disk failure (good luck betting on that). However since it would require 2 drives in one of the 5 RAID1 arrays to fail at the same time that is rather unlikely. Also with a 2 drive RAID1 (which is all you are concerned with if a single drive fails in the RAID10) the rebuild time is much much faster than any RAID5 rebuild and does not effect the performance of the array as drastically as RAID5 or RAID6. Since we use our SAN for an Oracle RAC I/O performance on both writes and reads are important.
Other bonus RAID10 scales to larger sizes without reducing the fault tolerance like RAID5 and RAID6. Course the cost is more drive space.
RAID-10 is sweet, I'll give you that. If my laptop could take 1 more drive, that's what I'd be running. Yeah, good luck getting the lucky one against the odds on all 5 proper disks failing the in the 10 disk array. I don't even know what those odds are, but they've got to be really fricking high, and not in your favor!
I've had a SimpleTech NAS for years and am totally satisfied.
