New to UPS here, and I'm just trying to figure it all out...
I'd like to have these items plugged into my UPS:
-Desktop computer
-NAS
-1-2 external HDDs.
Maybe:
-Monitor
-At some point I may want to get the 5 bay expansion unit for my NAS (DX517). I assume I'd need to calculate/factor in the wattage/VA of the expansion unit when buying a UPS?
Don't need:
-Router/Modem - 2-in-1 unit supplied to me via my ISP. Don't care if anything happens to it as they'll replace it for free.
Based on these items, how many watts/VA do you think I'd need?
1.) I prefer using something that can auto-shutdown my equipment when the power is cut. I only need a UPS that will keep the power online long enough for my devices to auto-shutdown.
2.) In addition to a power outage damaging data, can a power outage also damage/corrupt an OS like Windows or DSM?
3.) Can you really lose/corrupt disk data even if the platter isn't reading/writing at the time of a power outage?
3.) I sometimes notice what appears to be "brownouts" where my lights will flicker for half a second in my room when a roommate starts up a washing machine. Is it a big deal to protect against? If so, I should get a UPS with a Line-interactive?
4.) I checked out the APC UPS calculator. Do you guys trust "configure by device" > Select Desktop/Monitor to provide the correct VA/Watts?
5.) Is this accurate? "Buy a UPS with a Volt/Amp rating 50-75% above whatever the typical wattage load from electronics will be."
7.) From using an online volts-to-watts calculator is this accurate?
a.) External HDD = 12V DC 3 AMP = 36 Watts (vA)
b.) Monitor = 100-240V 1.5 AMP = (Not sure how to calculate two different voltage values?).
c.) NAS = Synolgy DS918+ = 12V 8.33 AMP = 100 Watts (Does this value change depending on the HDDs you're using?)
Because I notice for the expansion unit: "Power consumption is measured when fully loaded with Western Digital 1TB WD10EFRX hard drive(s)." And I'll be using 10 TB drives, not 1 TBs.
d.) Computer (according to APC) = 175 Watts. Seems kinda low...
-Desktop computer
-NAS
-1-2 external HDDs.
Maybe:
-Monitor
Don't need:
