Antimatter
- Jun 6, 2003
I have several questions which are listed below.
System spec:
5+ sata harddrive
1+ gigabit ethernet
Pentium-M or core lines cpu for softraid.
Goals:
Try to get near harddrive speed via gigabit ethernet.
This system real only purpose is to be a file server, along with some other limited stuff such as centeral logging database and so forth. But if I don't get enough money to make a real server I might burden this box with some serving duties.
1) It certainly would be cheaper to get a motherboard that supports Pentium-M or Core lines, with 5+ sata port on the motherboard, but my concern is will performance suffer? Why I'm asking this is, the sata port on the motherboard and the gigabyte ethernet port probably shares the same bus...
2) If there is going to be a performance degeration from using onboard gigabit and onboard sata ports then I would like to find a motherboard that supports PCI-X or PCI-express for the sole purpose of decedating a whole bus to the harddrive array, and another bus for the gigabit ethernet. Anyway I did find a few such as DFI 855GME-MGF, but this leaves us the problem of finding a sata controler for PCI-X or PCI-express that does not have an onboard RAID, and is well supported by linux or BSD.
3) I'm also wondering if products like these are any good Exteral drive cage, I was thinking of perhaps building the system in a shuttle case, then attaching one of those exteral drive cage to a card that accepts outside sata ports. So would those solution work, or would it be better to go for an all internal solution in an mini-tower?
Hoped system spec:
Pentium-M, Core Duo, Core 2 Duo.
5+ harddrive in a softraid by linux/bsd
Maybe a DVD burner
1+ gigabyte of memory
gigabyte ethernet
Fits in a mini-tower to med-tower.
Thanks!
System spec:
5+ sata harddrive
1+ gigabit ethernet
Goals:
Hoped system spec:
Maybe a DVD burner
gigabyte ethernet
Thanks!
