NAS PC Casse ?
Phimp
I'm planning for the build of a FreeNAS box.
I'll use 3 750gb drives at first then probably throw in a fourth later on.
And I'm looking for a shorter case, like the shuttle-style of cases.
But apparantely most Shuttle or Apevia cases like that come with absolutely worthless PSU's. I'm hoping to not have to replace the PSU, so it could support a couple hard drives and a low-end system without issues and be reliable.
I'm tempted to just throw this all in an Xbox case and have an external PSU cuz it would be cheaper. :p
Any suggestions?
What did other NAS PC builders use?
If you're looking for a NAS system, you probably want RAID for the hard drives, look at the chipsets (intel southbridge chips with a -R suffix supports raid - ex: ICH8R, ICH7R and so on), unless you want to have a RAID controller card. I'd look at small cases without a PSU, and I wouldn't necessarily go for a barebones kit unless you find something absolutely perfect (which probably won't happen, but ya never know).
My suggestion: look around mATX cases without PSUs that can hold as many HDDs as you want, and remember you can put them in external 3.5" slots or put in expansion brackets - usually either 3 HDDs in 2 5.25"s or 4 HDDs in 3 5.25"s
well, im going through my choices for the system in the "Disk Storage Systems" subform, I already have a thread for the inner workings of the NAS.
I'm using FreeNAS (if I can figure if it's possible to expand raid5 w/ it) and using it's software raid function, pretty simple&easy.
I have the components roughly picked out. really cheap though, not too worried about getting max performance because I'm working with a fairly tight budget for everything.
But ya, I just can't find a small micro/miniATX case that isn't expensive and doesn't look like it was made by Mattel.
It doesn't really need to include a PSU but I have no idea what to look for as far as quality in PSU's and it needs to be shorter if it's gonna fit in a tiny case.
Thanks for the suggestions on the chipsets!
But most micro/miniATX cases have 2 internal 3.5" bays, and 1 or 2 external 5.25" bays and some have just one 5.25" bay with an external 3.5" bay for a floppy. So most would fit 3 drives easily, and 4 just fine. If I moved up to 5 in the future, It'd require a little metal work but I'm not concerned about that far ahead.
Do most people just go for the typical atx desktop case that's cheap and has a decent PSU? Then throw it in a closet? I will go that route if no micro/miniATX cases appeal to me at their price.
I found a great case for you. It runs a bit expensive, but it is a mini ITX case with four 3.5" Removable drive bays. Perfect for a NAS or File Server.
http://www.chenbro.com/corporatesite/products_detail.php?serno=100
http://techawave.jitbid.com/techawa...wer-mini-itx-4-x-sataiisas-no-p-p-555801.html
Wow! That case is a thing of beauty! I fell in love when I saw the pictures.. but my heart was broken when I saw the price lol
Why'd you have to show me that? Now I may just end up going way over budget! haha
Realistically though, I can't just can't bring myself to pay that much for the case and still have to look for a PSU.
If it were $100 cheaper I'd be all over that!
I just ordered this last night:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3301330&CatId=32
Might not be on the shorter side but it includes the removable drive bays and you even have room to add another remove drive bay in it.
Seems a bit more in my price range, I'd probably jump for it if it came with a reliable PSU, but I'll definitely still consider it.
How about a small Thermaltake case
and throw in a decent PSU? What psu though? I've re-used PSU's so many times that I don't have to purchase them very often so I'm not familiar with the reliable brands.
Edit: I was hoping for a non-tower case, but my budget is cutting it close after picking out hardware. So how about this CM case? Decent PSU?
Wow, I hate shipping costs... any good deals on case+psu at Best Buy B&M lately?
