NAS compatible with SAS and iSCSI?
L33T
Is anyone aware of any NAS solution with compatibility with 3.5in SAS disks and iSCSI, with at least 4 bays? Thanks.
You may need to add a SAS HBA like LSI 9207, LSI 9211 or a cheap IBM 1015
2.
On ZFS you can create a logical unit from a file, a ZFS filesystem (zvol) or a raw disk.
From this logical unit, you create a target/Lun
Actually the drives have already been purchased. They're a set of four 2TB SAS drives. It's preferable to keep the cost under $700.
Unfortunately, devices like Synology won't work (they're all SATA, except at the very high end).
