Narrowed it down to two DFI vs Asus!
i acutally was looking at the same options then i found a rampage ii extreme cheap. cant really go wrong with asus
Personally I'd go with DFI. I loved the last two I had. I'm still not ready to trust Asus boards again.
another vote for DFI, even though my P45 lan party jr. drove me bonkers
:D
I have had nothing but OC fun from my P45 lan paty JR. :)
Another vote for the DFI MB.
Take a look at the new G. Skill DDR3 though.
i would go asus. i had a bad experience with dfi. they could be better now ...........but im not likely to try them again.
this is just my personal experience but I'd go with Asus.
last two systems i've started out with DFI boards based on their reputation from users and those systems ended up having asus mobo's. both DFI's died out on me about 3 months after use and it wasn't like i was tweaking them that much either. when i RMA'd one of the boards back to DFI, they said I had bent one of the pins on the motherboard and it required an extra $40 to fix it. i don't see how that happened since the mobo died while i was using it regularly and i shipped it back carefully to them. either way, personally i'm staying away from DFI and the Asus boards have been rock steady for me.
After reading up on some of the horror stories with DFI RMA process I might just settle for the EVGA board. Any thoughts on how stable that board is with 24.7 overclocks ?
If customer service / RMA stuff is a concern, then EVGA is the way to go.... that board is good once you get the settings right, it's a bit finicky at first but once you spend a bit of time setting the bios up how it likes it then you shouldn't have any problems.
+1 to this. I'm an EVGA Classified owner and I'm loving it. My buddy originally bought an Asus P6T Deluxe v2. After a few weeks, he ended up returning his ASUS and bought an EVGA Classified. He has no regrets on the upgrade.
dfi rma was fast for me (975x, rd600, P35 mostly me going way to far with the bios) and i have the p6t and its solid as a rock. personal prefrence on color scemes or NB cooling
I would consider the Rampage II Gene unless you really need a full ATX board ( really think about it ). The bios options are superior and even higher quality VRM design. Additionally in terms of service both boards offer an amazing rma service. Not alot of users know about. I have linked the information below.
http://livesupport.asus.com/aps/
Additionally i would save your memory on the memory Corsair offers fantastic memory but i my opinion the performance is not worth esepcially if you are not becnhing.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227388
I'm currently running the Jr version (mATX) of your DFI option with the same RAM and CPU. LOVE IT!! I've only got a C0 chip but I've got it up to 3.8GHz. If you've got a window case and UV lighting, the board looks dynamite!
I have the DFI board and it is a fantastic board. I am a novice overclocker and have found this board very easy to work with and have not found the options overwhelming. It also has a superior layout to the Asus board should you want to use all 3 PCI-e slots.
