Hello,
I'm running an all in one with Solaris 11.1 Text install, napp-it release nightly Nov.03.2013.
All my ZFS Filesystems show 'on' under NFS. When I click on, set to off, it doesn't change. I really briefly see flashed
"sudo unlink: command not found"
Every one of my ZFS in the pool show as enabled, I know some of them never were.
Any ideas?
I can't find a way to look at the logs of what happened, and the bottom of the page scrolls by way to fast to read.
This has worked for a long time, so when asked what did I change:
Folder-ACL was set to 777 for each of them. I reset ACL to modify.
I also tried to add local users and delete the everyone@ in SMB Share.
Any help will be appreciated.
Edit: I used showmount -e at command line, and it shows 4 folders shared with NFS. Napp-it shows 8.
Thanks,
-Brent
Any ideas?
Thanks,
-Brent
