DigitalDaz
- Mar 3, 2013
I currently have a setup, ZFS but not using Napp-IT made up of the following.
2U chassis with 8 hotswap bays, i3 processor with 32GB ECC RAM, 8x1TB Seagate spinners. 2x256GB Intel SSDs as L2ARC.
The box is the storage for a small ESXi setup. The ESXi and the storage box are connected using QLE2462 fiber channel cards.
Obviously my box is a single point of failure, its been running great for a good year at least now.
What I am planning to do is duplicate the above exactly, I'm not particularly bothered about HA and I definitely want to stay with ZFS.
I figure if I put Napp-IT on both boxes and get the replication plugin going on both boxes I can split the load between both boxes and replicate to each other. That way, I hope, I should only lose half my setup should one box fail and I should be able to pull the replicated volumes up fairly quickly and get them back to life. That's the plan, anyway.
I will probably do the replication by bonding 3 of the gigabit ports, there's 4 on these boards. I would like to use 10 gig for the replication but have no more PCIe slots
My 8 spinners are in 4 striped mirrors.
What do you think?
What do you think?
