Red Squirrel
- Nov 29, 2009
Going to be moving my online server to a new provider. There are multiple zones pointing to the same IP, when I switch to a new server/provider I then have to change that IP in each zone.
Is there a way to create some kind of alias so I only need to do it once? I use CNAMEs within a certain zone but you can't use CNAME across other zones and can't use it for the "main" record (ex: example.com). Is there any way to do this?
Also going from CentOS 5 to CentOS 6 in the process, so I'm hoping the syntax of the zone files did not change.
