Name That Splooge: MB Failure Point... Pics
NoEcho
Have an older Epox 8K3A.... it's been a warhorse. Has been overclocked most of the past 3 years. Recently developed a few problems. HD failed (boot sector) so I went in to add a new one. Spotted the following funk:
computer
Looks really bad.
Here's the question... what the hell is that charred stuff? There's no capacitor there (far as I know) so it shouldn't be cap juice. There's that magnet there... guessing it might be a voltage regulator spot. But it looks like something melted down or blew out... and I don't see anything at the point that could have done either. The mobo has been laying flat for the past few months too.
computer
Roger. This is the first forum access I've had as [H] crashed immediately after I posted. Amending links now.
In the interrim I've vacuumed out the spot, tossed in an old 10 G HD and loaded up xp on it. Made it through install and patching so mobo seems to be okay.... although voltages were hopping around a bit during bootup when I went into bios to check system health.
Not sure.
Still wonder what that funk is/was.
replace the toroid's and i think you'd be all set, they burned themselves to death it looks like :eek:
Cool. Progress. Thanks. WTF - other than a toroidal object - is a toroid? Why would they overheat? Would they be sheathed in enough liner or surrounded with some sort of lube that - when overheated - would flow out and burn like the splooge in question?
Toroid coil inductors are part of the power section on the mainboard. They confine the magnetic field inside the ring...
There is no way in hell I would reuse that mainboard with the toroid looking like that.
Check the PCB under the FETs for any discoloration...also look for bulging capacitor tops or leaking bungs...
Nuked FET's are a classic example of failing capacitors...
yeah, it looks like its time to replace that mobo, something got awfully hot to do that much charing, i wouldnt want the risk of killing other components
