Name me a GFX card
Private TEMPLAR
Because im too lazy to bother having to doo all teh reasearch and find out all teh Pro's and Con's about different graphics cards, i decided to start a thread to ask people what buget graphics cards can i get that give better proformance than an old 6600GT...
So...shoot away
I moved from a 6600GT(agp) to a Leadtek 7600GT (Pcie) - big improvement. With a simple pencil mod that card overclocked to an evil 666 core /840 ram.
Then two months later, for the same money I found a Leadtek 7900GS. With a simple conductive pen mod, it overclocked from 450/560 stock to 675/800. Newegg one on weekend special for $159 after MIR. Great value.
So...shoot away
Not enough information. AGP or PCI-E? How much are you looking to spend?
fulls specs
AMD 3200+ 64 2.0 Ghz
Nvidia Nforce 3 mobo
1gb ram
i only have a 3500watt psu, i dont have the cash to upgrade that right now, i need to get a graphics card, my 6600gt idels at 70 degrees
it also needs to be a PCI-Exress
i have a budget of about $250
fulls specs
damn... ill go ahead and assume you meant 350 :p
7900GT or 7600GT for nvidia
1800XT or 1900XT for ATI
should be about in that price range, but since you are powersupply limited, 7600GT is probably the way to go.
I would say 7600GT as well. I ran an X800XL with a generic 350W PSU and it was fine. I assume the 7600GT would be okay too.
I was gonna say is there an nforce3 with pcie aswell... I don't believe so.
On that note if you don't wanna upgrade all around your best bet is gonna be the BFG 7800gs, or the powercolor 1950pro's that will be coming out soon.
If your budget is $250, then you can get a 7900GS and a good 450-500W power supply for that price. That would be my suggestion.
Yes, there are PCI-E NF3 boards, and the OP apparently has one. I know that there's a DFI LanParty NF3 board with PCI-E, among others.
the 7900GS will run on a 350w PSU, if it's a GOOD PSU.
If it's a "super sparkle sunshine power awesome supply" I'd be wary of going over an X1800 or 7600gt ;).
Actually, Sparkle makes very good PSUs ;).
Also, I think you mean X800, not X1800.
350 Watt PSU can support anything from the highest of the high end to practically nothing depending on its quality. In other words, shoddy units will use all sorts of tricks to boost that wattage number and actually be capable of 200 W or less under real world conditions, while good ones can deliver 400 W or more under real world conditions.
Assuming the worst, I'd be leery of going over a 7900 GS or X1950 Pro. The latter card is what I would recommend. Should be a little faster and has ATI's IQ improvements, HDR+AA, HDCP, and AVIVO for video playback.
If you know it's a high quality PSU, I'd go for an X1900 XT 256.
My 7900GS system requirements say: min 350W PSU with 20A on the 12V rail.
Newegg had an evga 7900GS for $159 after $20 MIR, though the Gigabyte for $189 after instant rebate looks like it has a better cooler than the evga. Though the evga has the step-up program.
I did the 1.5V volt mod on mine yesterday - it took five minutes and a $6 bottle of conductive paint (a "repair-car-rear-defogger-circuit" item from walmart's automotive section) and a small modeling paintbrush. I freehand painted in a small thin line then dried it with a hairdryer.
Like I said, core went from 450mhz to 675.
Temp went from an idle of 40C to 46C, and after an hour of Counterstrike Source max temp was 70C.
If your to lazy to do the research then your to lazy to use the card, Get real!
The requirements say 350, the actual measurements say about 200 for the entire system at peak 3D. Obviously, if you voltmod and overclock by +50%, you need a lot more, but at stock, I wouldn't worry with a 350 Watt unit, even if it's a piece of crap. Maybe if he's running a Prescott, but not otherwise.
What is a pen mod? Please explain :( Running brothers 7900GS at 590/900 right now :)
Ahhh.., noob! Do some more research on your own! That's what google is there for.. just google "pen mod" and stuff like that! Bah!
Well I had tried it on wiki and pen mod wasn't very good but pencil mod on google worked :p I knew asking that question would only get a responce like that.
Google "The Simple & Concise 7900GT Voltmod Tutorial"
The 7900GT conductive ink pen mod seems to work on reference 7900GS - worked well on my Leadtek.
I did the 1.5V one, connecting ground and D508 & D511 - unlike the photo where two legs are drawn down from the line going to ground, I just painted one down the middle and touched both.
