Red Squirrel
- Nov 29, 2009
I've been playing with Pandora and there are a few aspects of it I don't like. One is the way the threshold setting is very confusing, and also the fact that I cannot set the threshold to be high AND low, only one or the other. Ex: I can monitor a value and if it goes above 50 I get a warning, if it goes above 60 it goes critical. But I cannot monitor a value and make it warn if it's below 10 OR above 50 and make it go critical if it's below 0 OR above 60. Can do low, or high, but not both. Basically I rather set a range, and tell it to alarm if it falls outside of that range. Much simpler.
Also how easy is it to deploy agents? Is it a simple binary that will "just work" or some complex thing with tons of dependencies? That's the nice thing with pandora is the agent is very simple, and it's very easy to add custom monitor points like temperature from a text file as a single monitor point value is gathered from a command, so I can use sed/grep etc to grab a value from the Linux environment whether it's a text file or a command's output. Can nagios do this as well?
Also does Nagios use Flash? Pandora uses it, and flash locks up all the time on my system so that alone is reason enough to switch to something else.
