n3wbified fan instilation question =/
Im looking into a lian-li case, and it only has an intake and exaust fan, so im worried about the temp. Is it possible to add more fans?
With a drill bit or a Dremel, anything is possible.
If it has enough factory holes for more fans I coulndt say unless you posted which model case you are looking at.
