N00bie to Dual Monitors... Help.
Mojo
I recently bought a new 19" LCD. And I decided to attach my old 17" Flat CRT to my computer as well, to have a dual monitor setup.
Working well so far, I have downloaded Ultramon, and I now have separate backgrounds on each monitor and the taskbar figured out pretty well. I was wondering if you can use two mice, one designated to each monitor. And if so what software should I use. I need this feature because the main reason I want this dual monitor setup is so I can play games while chatting/chaning music settings/surfing the web. And as you all know you need a mouse for both activities. Ultramon does have a hotkey feature that lets you press a key and your mouse will switch to the other monitor, but this won't work in my games (MOHAA is the only one I've tried thus far). It makes me minimize the window first which defeats the purpose all together.
Any other pointers concerning dual monitor setups will be greatly appreciated.
Unfortunately, as far as I know this isn't doable. There might be some really messed up config hack you could do in X on Linux/BSD/etc, but other than that it doesn't work. (Actually, I'm pretty sure that would... run 2 X servers, then just config one display to use a PS/2 mouse and the other to use USB)
Basically games (full screen apps in general) just minimize when you click on the desktop in a dual monitor setup. Well written games won't let the mouse leave the game (so you have to alt-tab, etc). The one possibility I can think of is to try running your games in a window. That might let you switch out w/o leaving the game.
Of course, getting a cheap PC to play music and chat on & hooking it up to your 17" is another possibility. You could use a KVM and only attach the KB to it.
