n00b stepping question
Ludic
How does one tell from the outside of the box which stepping revision is inside? This is for Quad Core Q6600. I'm going to purchase one, but I want to make sure the one I get is G0 without opening it, and I'm not familiar with Intel's labelling (as I've been using AMD for the last decade or so)
Thanks, that's the info I needed. Intel's site has the stepping codes, but doesn't show where you can find thsoe on the box.
