[moved over from a separate topic]
Hey guys and gals.
Thanks so much for your help thus far, really appreciate it.
Ok, here's an update with the actual specs of my comp:
1 M5269 PROCESSOR, 80546, 3.2, 1M, PENTIUM 4 PRESCOTT DT, 800, D0
1 U2424 CARD (CIRCUIT), PLANAR (MOTHERBOARD), DIMENSION, XPS-G2
2 K4230 DUAL IN-LINE MEMORY MODULE, 512, 400M, 64X64, 8K, 184
1 X2603 CARD (CIRCUIT), GRAPHICS, 128MB, R350, PROFESSIONAL, DIMENSION
(radeon 9800 AGP^^^^)
1 U4001 HARD DRIVE, 160GB, Serial ATA, 8MB, 7.2K, WD-XL80
Allrighty, here's the plan:
I'm going to upgrade the vid card to the X1650 Pro 512 mb:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102073
And I want to upgrade the memory. Now, as far as memory goes, I'm LOST. All I know is it's DDR and 400mhz. So..I was looking at this?
http://www.newegg.com/Product/Product.aspx?Item=N82E16820211014
I'm pretty broke, can anyone recommend some cheap but quality memory that would be compatible with my system? Let me know what you guys think.
Thanks,
-Myth
Hey guys and gals.
Thanks,
-Myth
