n0s0upf0ry0u
- Dec 24, 2005
hey everyone,
new member and first post, so be gentle.
just recently put together my first system-
msi k8n nf4 platinum sli mobo
athlon 64 4000+ san diego CPU
ocz pc3200 ddr-400 1GB x 2 DIMMs
7800GTX 256MB GPU (one unit)
antec TPII 550 PSU
system worked fine running windows (with all the default bios settings), but when i tried running a few games such as half life 2, need for speed most wanted and quake 4 at 1600x1200 (without aa), frame rate was poor, even after switching to a lower resolution of 1280x1024. haven't played around much with the bios or overclock settings, as i wouldn't have expected this poor performance even at the default settings. the only thing i tried was turning on "agressive overclocking" setting, which made windows unbootable. any ideas where my bottleneck might be, or how i can boost performance?
second question- whenever i run the corecell software that comes with msi mobo's, my cpu fan alarm goes off. the fan speed is around 3300 rpm's with idle temps that look ok. my fans are plugged into the antec TPII connectors, not the mobo connectors.
any answers/advice to either question, including that of the "RTFM" type (as long as good sources included) would be HUGELY appreciated.
thanks everyone,
abe
antec TPII 550 PSU
thanks everyone,
abe
