n00b problem when trying to watercool SLI
FatboyHK
I think you guessed it right, when I try to fit the EK blocks on both cards, I found that there is no room for the barbs.... My mobo is a Asus A8N32, those PCI-E slots are quite close to each other (2 PCI slot), what should I do??
have them both go out from each other and then use two Y fittigns to run them in parallel
