n00b crossfire question
pookguy88
I'm just setting up my 6970 crossfire setup and since it's my first time doing this.. how come there's 2 crossfire notches on each card? should I use both crossfire adapters or just one? if one, which set of notches do I use? the ones closest to the input (dvi, hdmi) ports or the ones nearer the rear of the card??
so confused.. thanks!
Use the ones at the top of the card. The bottom ones can be used for a third card.
