so, i am working on a hypothetical build. it will have the most up to date hardware, and/or software. here is what i have for hardware so far:
SILVERSTONE TJ07-BW Black Aluminum ATX Full Tower Computer Case
2 x Western Digital VelociRaptor WD3000GLFS 300GB 10000 RPM SATA 3.0Gb/s Hard Drive♥
2 x Seagate Barracuda ES.2 ST31000340NS 1TB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
ASUS VW266H Black 25.5" 2ms(GTG) HDMI Widescreen LCD Monitor - Retail
3 x EVGA 01G-P3-1284-AR GeForce GTX 280 SSC Edition 1GB 512-bit GDDR3 PCI Express 2.0 x16 or 2 x GTX295's
Saitek PK17U Black/Silver USB Standard Cyborg Keyboard
Silverstone SST-RADSUPPORT09 radiator Supporter
ASUS P6T6 WS Revolution LGA 1366 Intel X58 ATX Intel Motherboard
Intel Core i7 940 Nehalem 2.93GHz LGA 1366 130W Quad-Core Processor
TRIPP LITE Power It! TLM615NC20 6 Outlets Power Strip
Swiftech MCR220-QP Liquid Cooler Radiator
TRITTON AXPro True 5.1 Gaming Headphones with 8 Precision Speakers, Removable Microphone
2 x OCZ Platinum 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600
8 x Scythe SY1225SL12SH 120mm "Slipstream" Case Fans
Koolance 1300/1700W Liquid-Cooled Power Supply, Rev 1.5
so i got this far no problem hardware builds are easy. here is the hard part...
i want to cool just about everything in this case, with a TEC assisted waterblock for the CPU and some TEC assisted GPU full coverage blocks if they even exist. here is my current loop idea:
res-pump1-TEC CPU-rad1 (240mm)-vreg1-vreg2-split to RAM blocks-NB-SB-ram hot gets spliced back in-rad2 (240mm)-pump2-tri SLI vid cards (or quad w/e)-PS-rad3 (480mm )-then back to the res.
note this loop only has the CPU TECA. so could some people with knowlege give me some pointers on waterblocks and teh like? if there is a better case out there tell me. also it seems that the only TECA waterblock i can find is made by swiftech, but it is copper with an aluminum top. and if anyone knows of some full coverage motherboard blocks i would like to know them too.
thanks
master6
thanks
master6
