I have a small 10GbE network at home (used for work) consisting of a NAS and a bunch of ESXi hosts.
I recently decided to take the plunge and spend far too much money getting my iMac (i5 / 16GB DDR3 / SSD) onto this network using a Sonnet Echo Express thunderbolt enclosure, Myricom 10G-PCIE2-8B2-2S, and some 10Gb SFP+ modules.
Was extremely painless to install and had it all running very quickly, but I seem to be hitting a limit of 4.37Gbit/s and while this is probably more than adequate for my workstation , I would like to be able to get slightly better performance considering the price I paid.
I am 100% the DAC cables, SFP+ modules and fiber cables are not the issue here as I have tested them in other NICs and all get performance very similar to the below
Next the iperf tests on the iMac....
Read somewhere changing the tcp window scale option can improve things, not that I have any clue what this is, bug figure I'd give it a go as by default it is on
And the results, well that didn't do much good
I have followed every tip inside the Myricom readme here https://www.myricom.com/scs/READMES/README.myri10ge-macosx
And a whole range of tips/changes here https://www.myricom.com/software/my...hoot-slow-myri10ge-or-mx-10g-performance.html
Also tried the suggestions for the iperf options...
But still around the 4.37Gbit/s limit, starting to think maybe the thunderbolt link is limiting it somehow or the Sonnet enclosure isn't good enough. I think the card only runs at PCIe x4 mode in this enclosure but that should give it enough bandwidth to max out 10GbE
On the Myricom readme they provide a way to show the PCIe bandwidth...
I seem to be limited to 540MBs which I'm sure I could live with but would like to max this device out if possible!
Today I may try test the card inside a Ubuntu box to see how it performs, just to double check the NIC is able to perform.
Any suggestions on changes I could try to improve this?
Code:
iperf -c 10.0.21.102
Client connecting to 10.0.21.102, TCP port 5001
TCP window size: 22.9 KByte (default)
[ 3] local 10.0.21.123 port 50466 connected with 10.0.21.102 port 5001
[ ID] Interval Transfer Bandwidth
[ 3] 0.0-10.0 sec 10.9 GBytes 9.39 Gbits/sec
Code:
TCP window size: 129 KByte (default)
[ 4] local 10.0.21.124 port 53614 connected with 10.0.21.102 port 5001
[ 4] 0.0-10.0 sec 5.09 GBytes 4.37 Gbits/sec
Code:
➜ ~ sysctl net.inet.tcp.rfc1323
net.inet.tcp.rfc1323: 1
➜ ~ sudo sysctl -w net.inet.tcp.rfc1323=0
net.inet.tcp.rfc1323: 1 -> 0
Code:
➜ ~ iperf -c 10.0.21.102
TCP window size: 128 KByte (default)
[ 4] local 10.0.21.124 port 53661 connected with 10.0.21.102 port 5001
[ 4] 0.0-10.0 sec 2.32 GBytes 1.99 Gbits/sec
Code:
~ iperf -c 10.0.21.102 -w 768k -l 256k
TCP window size: 769 KByte (WARNING: requested 768 KByte)
[ 4] local 10.0.21.124 port 54258 connected with 10.0.21.102 port 5001
[ 4] 0.0-10.0 sec 5.04 GBytes 4.33 Gbits/sec
Code:
➜ ~ sysctl net.myri10ge | grep dma
net.myri10ge.en3.dma_read_bw_MBs: 806
net.myri10ge.en3.dma_write_bw_MBs: 825
net.myri10ge.en3.dma_read_write_bw_MBs: 978
net.myri10ge.en4.dma_read_bw_MBs: 805
net.myri10ge.en4.dma_write_bw_MBs: 825
net.myri10ge.en4.dma_read_write_bw_MBs: 978
