I need to order a case ASAP and haven't heard back from support at MyOpenPC. I need to confirm the depth of the Monster case because the shelf it will go on is very shallow.
The dimensions are given on Amazon as 10.6 x 14.4 x 14.8 inches but I'm not sure which number represents the depth. I'm hoping it's 10.6.
I have no idea how to read the dimensions on this image: http://ecx.images-amazon.com/images/I/41wyp6aARXL._AA300_.jpg
I can convert from mm to inches, but the drawing makes no sense to me.
If anyone knows, I'd be grateful the answer.
Thanks
http://www.amazon.com/MYOPENPC-Monster-Transparent-Computer-motherboard/dp/B0042RMP32/ref=pd_cp_e_2
Thanks
