Does anyone else here have the MYHD-130 card? If so, have you been able to get it to work with any other software than the MYHD software that it comes with? I'd like to get Snapstream to work on it and/or add a PVR150 to the same machine so that it will record HDTV via the MYHD-130 card and regular cable (digital, tuned via IR blaster) via the PVR150. The bottom line is I'd like to have a multituner system with the MYHD-130 and whatever else for my digital cable.
Thanks,
Sonny
Thanks,
Sonny
