aethelwulf
- Nov 20, 2007
So I've been reading up and trying to get as much info as possible before I barrage you all with questions. Anyway, I don't have any specific price cap but I plan on spending approx. $1000-1500. I've put up links to newegg for everything, since it's easier, and I haven't really comparison shopped prices yet (I plan on doing that after I finalize my build). It'll be used mostly for gaming, some photo editing, and watching movies. It's been about 4 and 1/2 years since I built my last rig, so I'm a bit out of touch with some new tech.
Intel Core 2 Quad Q6600 Kentsfield 2.4GHz 2 x 4MB L2 Cache LGA 775 Processor - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115017
-- I DO plan on buying this at clubit for G0 stepping as I would like to O/C to about 3Ghz.
Thermalright Ultra-120 Extreme CPU Cooler - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16835109140 and
Scythe S-FLEX SFF21E 120mm Case Fan - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16835185005 and
Arctic Silver 5 Thermal Compound
http://www.newegg.com/Product/Product.aspx?Item=N82E16835100007
--seems like the best air-cooled solution out there, as I don't have any plans for liquid cooling. I am wondering what the difference between the SFF21D/E/F letter designations on the fans are per newegg.
Motherboard, I'm going to go with something on the P35 chipset, but I haven't picked one out yet. I've used Asus in the past, so I'm not too sure about what brands to look at. I'm also still debating on what features I want out of the board. Mostly a decision of RAID or no.
CORSAIR CMPSU-520HX ATX12V v2.2 and EPS12V 2.91 520W Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139001
--as per many newegg suggestions.
Western Digital Caviar SE16 500GB 3.5" SATA 3.0Gb/s Hard Drive - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136073
--I'm not completely sure on the HD, so I could use some help with this... I was thinking of getting 2 of these, but I'm open to suggestions. I've also used seagate in the past, so I don't know if this will be a step down for me. Also, I noticed that the equivalent samsung is pretty much the same price. I'm debating on whether or not to do RAID, and as I've never dabbled in it before I'm wondering what the advantages and disadvantages are.
PNY VCG88512GXPB G92 GeForce 8800GT 512MB 256-bit GDDR3 PCI Express 2.0 PureVideo HD Technology HDCP Ready SLI Supported Video Card - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16814133205
--Maybe not this specific brand, but it will probably be either PNY, BFG or evga.
Creative 70SB046A00000 7.1 Channels 24-bit 192KHz PCI Interface Sound Blaster X-Fi XtremeGamer Fatal1ty Professional Series - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16829102005
--Sound card.
mushkin 4GB(2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model 996557 - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16820146692
--I want to get a 2x2GB setup, but haven't nailed down a brand, was debating between this, G.skill and A data.
I'd also like to get a decent optical drive, but I don't really know what's good these days.
Logitech G5 2-Tone 6 Buttons 1 x Wheel USB Wired Laser Mouse - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16826104191
--Friend of mine has one, and I liked it a lot when I tried it out.
Logitech G15 Gaming Keyboard - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16823126179
--Don't know too much about it, but seems like one of the better ones out there and I like logitech products.
Finally, I'm not really sure what case to go with. I've been pretty happy with my Antec, but I'm open to suggestions. I'd like something styled fairly simply, in black (or black/silver) and no window. Something about like this in terms of style:
Antec Performance One P180B Black 0.8mm cold rolled steel for durability through the majority of chassis 1.0mm cold rolled steel around the 4 x HDD area ATX Mid Tower Computer Case - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129017
--I like this one, but I'm wondering about issues with power supply locations and I've also hear about problems fitting video cards.
All of this will be running on a Samsung 226bw, fyi. Thanks for the help!
--Sound card.
