My WCing Days Are Over...
Do you know what caused the leak, and are the rads your selling in the deal are the leaky ones?
Screws were screwed in too far. I've done this myself. It's a huge bitch and the radiators are not able to be repaired.
The rads are able to be repaired and was told direct from Thermochill to take them to an auto radiator shop or simply use a propane torch and 60/40 solder or JB Weld.
I killed a rad by screwing in too far as well. Thankfully it was a $50 rad. (yay inexpensive swifty!)
Due to where the screws enter the radiator, right under the built in shroud, it's exceedinly difficult to solder them shut.
It's possible, but it's not cheap. At least half the price of the radiator.
hey check your PM box maXXimus, i cant post in the for sale section of the forums because my post count is too low...trollFTL
