i built my wc setup about...4-5 months ago. i slowly started seeing a bubble forming in my rez over the last 2 months. finally last week i filled it up again. i checked my computer for any sign of water residue/coolant and there was none. if it was a leak its too small to notice i guess. i double checked my connections and everything seemed fine. i did notice some scale on my rad around where the elbow connection's are. could that be where im loosing my coolant? im using the ehh... i dont know what their called, you push the tube inside the connector and pins hold it in place. my brain is scattered at the moment. if you understand what im talking about, can i loose liquid from there aswell?
thanks for your help and time
