My Water Cooling System.....
SuddenDemise
I'm currently getting ready to build my new system (wont be done for at least a month) and I have decided to make it Water Cooled. So this is my first attempt at compiling parts for a Water Cooling System. All Parts are from DangerDen and CrazyPC. Let me know what you think.....
CPU Water Block: Danger Den MAZE4 for AMD 64
GPU Water Block: Danger Den Acetal MAZE4 GPU Water Block
Radiator: MCR-120 Black 120mm Radiator
Pump: Hydor L30 II Inline Water Pump
Reservoir: CrazyPC Dual 5.25” Bay Reservoir UV Blue
Tubing: PrimoFlex UV Blue 1/2ID Tubing
I had some questions on Additives; DangerDen offers MCT-40 a water alternative for Water Cooling. Is this something I should go with or should I stick with distilled water? Also can someone post a link to a good Guide for setting up Water Cooling Systems.
Please give opinions, thoughts and any adjustments you think I should make on my currently compiled Water Cooling System. Let me know if I left anything out that I need....Thanks
I would highly suggest going with a better block than the maze4 for the CPU. It is not a horrible block, but it is older tech. A DangerDen TDX or D-tek Whitewater are both good choices.
If you can fit it in your case, I would suggest going with a dual 120mm heater core. Personally, I am not statisfied going from my dual 120mm heatercore to my single 120. My temperatures shot up 8C all around. But hey, I am a performance freak :).
What video card are you cooling?
I'm still tryin to find a case to put all this in, like I said I'm in the process of building this, just compiling my parts. I will defintely switch CPU Blocks, I was told the same thing about the Maze4 by people on another forum. I'm going to be cooling a MSI 6600GT PCI-E. When I compiled this Water Cooling system I was going to get a 6800Gt but quickly realized that wasn't in my price range so settle for the 6600GT so I'm not sure if the Current GPU Block I selected will work for the 6600GT....
