My VM machine and FSB setttings
FAAmecanic
I have been having VERY low CPU 3dMark06 for my VM machine (from a previous thread)
I have done 2 benchmarks and both times my 3DMark06 CPU bench marks were 1636 and 1635 respectively. While reading one of my PC GAMER mags I see the dell XPS 410 (with slower memory (DDR2 -667) and a slower CPU (E6600) than mine) benched at 2,089 3DMark06 for CPU.
I also have noticed, while overall GREAT performance in games like Oblivion... my system seems to stu-stu-stutter alot.
System Specs:
eVGA Nvidia 680i mobo
Intel Core 2 Duo E6700 (2.67 ghz)
2 eVGA 8800 GTS in SLI
2 GB Corsair DDR800
SB X-Fi Extreme Music
WinXP Home SP2
I noticed while looking at CPU-Z that my Core speed is 1866.5 (is that right for a Core2Duo 2.67Ghz)?? My my Bus speed is 266.6 mhz and FSB 1066.6 with a multiplier of X7.... is that right? Could this explain my slow CPU speeds?
System Specs:
2 GB Corsair DDR800
WinXP Home SP2
contact heather @ VM and ask her to help you out... it sounds like either A) you were given the wrong CPU, or B) the multiplier was knocked down as a mistake...
you could TRY changing the multiplier to 10... if it doesnt boot, you know you need to send it back to VM
Is the CPU multiplier set at AUTO or X7? It should be set to auto, which is how we ship all systems except Raptors, which are sometimes overclocked. I'd try that fix first. Does the HARDWARE PROPERTIES show the CPU as E6700? Omega's right that it should be auto-detecting x10. Certainly call tech support if this is not the easy solution it should be.
The CPU-Z report does say I have a 2.67Ghz Core2Duo CPU.
I looked in the BIOS and the FSB Memory Clock Mode was set to Auto, but the CPU multiplier was at 7X (I didnt see an AUTO setting for CPU Mult).
I changed the multiplier to 10x and boot up seems fine. Maybe just a missed setting by the VM folks? I understand...mistakes happen. And I have been soo busy since Christmas getting a small business set up, I havent had time to really play with my VM machine.
So Chris.... setting my multiplier to 10x wont void the warranty or anything will it? (seems this is where it should have been anyway).
Thanks guys. Im off to re-benchmark.....
EDIT: AHHH thats the ticket
3DMark06: 11647
SM 2.0: 5465
HDR/SM3.0: 5883
CPU: 2313 (almost a 700 score improvement)
Damn...wish I would have checked the multiplier settings earlier.
Chris...Heather has been great in trying to troubleshoot this. BUT she did try and get your engineers to look/suggest what may be the problem, and either they never responded, or Heather has been "indisposed" for the last week as she never replied to my last email (I hope she is OK as she told me she has been working from home). I guess if I would have called Tech support I would have fixed this earlier...thats my bad.
Sorry to be a pest but I still would like to know if setting my Multiplier at X10 is OK being as it came from VM at x7..... and I do not see an AUTO setting in the BIOS for Multiplier.
I would also be curious to know how my PC was benchmarked at VM, and no one caught this?? Does VM use 3DMark06 and check the benchmarks as a final Quality Check against a range of what is reasonable for a compter with similar specs? If not I think it would be a great idea.
Thanks....
Thanks....
ten is the correct multiplier for the CPU you ordered, and i assume that is as high as it will go, meaning there can be no harm done :)
BTW, whos chris? lmao
Opps...I meant Randy :D I thought I was talking with Chris Morely (I think thats his name) before...my bad. and thanks for the answer Omega...I just wasnt sure if VM was like Dell in that most Dells will void your warranty if you doink around in the BIOS.
Good qustion. What is the extent that VM will let you 'doink'?
this could be completely irrelevant, but i just ran cpu-z on my VM comp, at my multi is also set to x7, granted my CPU is e6600.
shouldn't it be x9 for my CPU?
yes, it should be :S
Randy, Heather, any OTHER reports of this? this is odd :S
Humm.... I also would be curious to see if this was just a slip, or maybe a problem with the hardware.
Here was my CPUZ
Could it be Speedstep? The CPU in my VM computer runs at x8 multi all the time, when I turn off speedstep.
What exactly is multiplier? My Pentium 4 1.6ghz has the multiplier at x16, so what does that mean?
Guess I'll jump in here,too.
CPU-Z shows my Velocity Micro C2D 6300 multiplier at 6.
The VM poster said all should be set at auto,so it's curious that we have all these different settings. Should everybody be set at 10? Where do I check to see if I'm set at auto?
Thanks, Rich
Thanks, Rich
you change the multi in your BIOS.
i just got an e-mail from VM to change it from auto to manual, and adjust the multi.
and no, it shouldn't be x10 for all C2D as far as i know. it's x9 for my 6600. not sure what the multi should be for your 6300. i think Omega might help you with that :D
edit:
ok, when you enter System Clocks, highlight the CPU Multiplier and hit Enter. it will give you a Min and Max values for the cpu multi. just hit the Max value, hit Enter and save changes. done :D
What is a muliplier?
You take your CPU Muliplier lets say 10x and multiply it times your FSB speed to get your CPU clock speed.
So 10x 286 = 2860 Mhz or 2.86 Ghz
What I am seeing on CPUZ screens is 7x 266 = 1.862Ghz that is your clock speed.
I would call the manufacturer ASAP! Cause sumtin ain't right!
Thanks, Rich
you want a 7x multiplier.
if you have a second monitor, plug it in, leave CPU-Z or another CPU info tool running on that, and load up a game, if it stays at 6, there is a problem.
Thanks to you both for your answers.
Kinda figured this would involve the BIOS.
I'm just gettin' to where I'm not shaky scared of the registry,so I guess it's time to explore the BIOS. Just gotta be careful.
Can't help but ask here: What happens if you set your multiplier too high?
If it boots,and doesn't blue screen,will the higher setting work, or just cause other unstable
activity?
Thanks,Rich
What? Multiplier is a fixed variable it should not fluctuate with CPU load.
Unless the C2D is so new it has a fluctuating multiplier but I have never heard of this.
Please post our source.
thanks
FWIW
With CPU-Z running I opened a 3D game in a window and the multiplier jumped to 7,then dropped back down to 6 after the game was loaded.
Does that mean I'm set at auto?
Rich
thanks
The A64 using CnC can ramp down its speed, i havent used it, so i dont remember if it ramps down the multiplier, or the bus speed, but core 2 could be the same :p
activity?
Thanks,Rich
you should be able to set it too high, so dont worry :)
if for some reason you CAN set it above 7, give VM a shout...
I think I am also experiencing the same thing with my V/M Machine...
It should be set at x8 right?
And also, is it just me or is one stick running at only 540mhz?
Edit: I found out how come it was at x6. Since I'm new to Vista, I somehow figured it out. I just had to change the Power Options from balanced/power saving to performance and that automatically set my multiplier from x6 to x8.
I must be missing something here. I go into Control Panel/Power Options...and I dont see a balanced or Performance option.
Am I looking in the wrong place? I have XP Home.
