Installed Vista 32 bit on my comp last night and left it alone during the install. However, I noticed that when it rebooted and said it will now initialize for the first time it went to the blue error screen. The screen stays up for only 1-2 seconds if that so I can't read what the problem is. The blue screen goes away and the comp reboots. This time it goes to an option screen for whether I want to run in safe mode or not. If I don't touch anything it'll auto pick normal mode in which it will appear to begin windows and then just reboot. So if I left the computer alone it will continuously do this weird loop of reboots. After realizing what's going on I figured I'd try to load windows up from safe mode and fix it from there. As soon as I pick safe mode it comes back and says windows cannot load into safe mode until install is completed...that's a deadend. So at one point during my loop, the screen will ask for a few seconds to press any key to boot from disk so I tried that. It allows me to run system repair from the disk. I let it do this over night and checked it first thing this morning and the comp was STILL searching for any problems. I figured perhaps the program froze up so I cancelled and restarted the scan. I'll check the status after work today. Any opinions on this situation? I know lots of people are having issues but I hadn't seen any that had this issue yet. My system specs are in my signature.
