Well I've been waiting for the day when I would be able to post my own build. That day has come
Here are some shots of my newest build.
Specs:
Aspire X-QPack - Black Case w/ windows
Enermax Liberty 500w PSU
AMD Athlon 3700+ 2.2gHz Socket 939
Biostar T-Force 6100-939 MB
Western Digital 74gb SATA Raptor @ 10k RPM
Geforce 7900GT 256MB
2 x 512mb DDR 400 (from old PC)
2 12" UV tubes, UV sensitive IDE cable, UV sensitive SATA cable, UV sensitive cable ties
The first two images are just of the video card box.. had a little damage to the box but it works great (so far!)
First real order of business... making an AIR FILTRATION SYSTEM! This isn't as complicated (or as cool) as it sounds. Basically what I did here was go to the hardware store and look for any type of filter stuff they had. Being in Boston, it's a pretty small hardware store, so I found a filter for an air conditioner. It said it keeps out pollen and dust and it was $1.99 for a huge piece... good enough for the first experiment
Next came the cutting and the mounting on the QPack's side vents. This was pretty easy to do: measured the vent size, cut out a cardboard template, then cut the filter material accordingly. Next was how to mount it?
At the hardware store I got some velcro, not knowing how I would manage to do this but figured velcro would work somehow. (I got the velcro on the first trip, for those of you that were wondering
Turns out that the velcro is PERFECT for this. At least the hard side of the velcro... not sure that has a name or not, but you know what I'm talking about. The air conditioner filter stuck right to it! Just remember, you don't need 3 feet of 2" velcro to do this. You need about 6" of 2" velcro ... lol.
So I cut some small strips of velcro and mounted them on to the case along the edges of the vents:
Slap the air conditioner filter pieces that you cut out on to that velcro and you have yourself a pretty nice filter:
Now it was time to take my stuff and put it in, and make sure it worked:
What a mess!!!!!!
Ahh but the GeForce looks so good
Specs:
What a mess!!!!!!
