I have this USRobotics 9108 wireless router, which I have been using for maybe three years. Here is a link if you want to know more: http://www.usr.com/support/product-template.asp?prod=9108
It is been good three years, no real problems. However, I can easily tell that the coverage range of this router have been degrading over time. One reason I chose this specific router was because of its coverage distance. Now, if i'm not really close to it, I won't catch the signal! What gives? My brother have the same router, and in his place you can wonder around with your laptop and get a strong signal. His router is newer than mine and I wonder if he will have the same problem in the future.
Now, do routers lose their coverage distance over time?
I'm thinking of replacing my router and getting the Linksys WRT310N Wireless-N Gigabit Router.......what do you think? I want to be able to connect even if i'm in another room. The walls where I live are made of concrete.
Thanks
Thanks
