My turn for a new system... Please Eval...
TechLarry
RIP [H] Brother - June 1, 2022
Ok, it's my birthday next month so I've decided it's a decent time to build up a new system.
See sig for current system, which will be rotated out and turned into a dedicated online Sim-Racing machine.
New system will be running Windows Vista Ultimate (which is currently running on the Sig system). Sig system will be reloaded with XP.
Keep in mind, I am not into overclocking. While the new machine will be used for gaming, it is also my daily production machine and I require 100% reliablilty and do not have time to futz around with it. Once it's built, setup and imaged, I need it to 'just work' every day without fail.
Ok, here goes!
Antec Nine Hundred Black Steel ATX Mid Tower Computer Case - Retail
http://www.newegg.com/product/product.asp?item=N82E16811129021
Intel BOXD975XBX2KR LGA 775 Intel 975X ATX Intel Motherboard - Retail
http://www.newegg.com/product/product.asp?item=N82E16813121059
EVGA 768-P2-N831-AR GeForce 8800GTX 768MB GDDR3 PCI Express x16 HDCP Video Card - Retail
http://www.newegg.com/product/product.asp?item=N82E16814130072
PC Power & Cooling Silencer 750 Quad (Black) EPS12V 750W Continuous @ 40°C (825W Peak) Power Supply
http://www.newegg.com/product/product.asp?item=N82E16817703009
Intel Core 2 Duo E6600 Conroe 2.4GHz LGA 775 Processor Model BX80557E6600 - Retail
http://www.newegg.com/product/product.asp?item=N82E16819115003
Seagate Barracuda 7200.10 ST3500630AS 500GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
http://www.newegg.com/product/product.asp?item=N82E16822148136
What I'm not sure about is RAM. I haven't really had time to keep up with the DDR2 stuff, and I'm a bit behind on that technology. I want good solid RAM with enough headroom to guarantee perfect reliability on this high-performance system, but do not require exotic timings or voltages for overclocking. I've also read that the BadAxe2 has some specific requirements about RAM being 1.8v compatible and at certain timings?
Is that PP&C power supply a good one? Better alternatives?
I've always liked PCP&C psu's, good stuff.
As far as ram is concerned, why not take a look at Muskin? They aren't mentioned alot around here, but I live about two miles away from them and decided to give them a shot... good stuff again.
And that looks like a nice build...
I think I used Mushkin once in the past. Worked out well for me.
Thanks!
Good PSU but dont need that high, you could settle it down some like a 600 or so. Unless you want later sli and more. Just a thought
Since you won't be overclocking, you only need DDR2-533. If you plan on trying to overclock it later down the road, I'd suggest goin with some DDR2-667 at least. Go with either of these:
$114 - Corsair ValueSelect 2GB (2x1GB) DDR2-667 VS2GBKIT667D2
$130 - G.Skill 2GB (2x1GB) DDR2-800 F2-6400CL5D-2GBNQ
That's what I needed to know. Thanks!
Does it make any sense to go with DDR2-800 RAM ?
Only if you plan on OC'ing later down the road. DDR2-800 will allow for a 400Mhz FSB, which would put an E6600 at 3.6Ghz... which is pretty much its max on air if you're lucky. Though, I wouldn't go with the Corsairs you chose, simply because of that rebate. The Firestix use better ICs than those XMS2's. If you want stability, look for something rated at 1.8v.
Check out this PSU. CORSAIR CMPSU-620HX ATX12V v2.2 and EPS12V 2.91 620W Power Supply - Retail or the 520W (for a single 8800GTX)
You can save some money with the Corsair. The main differences are that it is has a bottom fan, is modular, and has two 6-pin PCI-e connectors as opposed to the PC P&C's rear fan, non-modular, and four 6-pin PCI-e connectors. Both the PC P&C and Corsair PSUs can power a 8800GTX SLI system. Corsair said they are working on 8-pin PCI-e connectors (link). Well if you really want the PC P&C 750W Quad, a revision with two more 8-pin PCI-e connectors will be available in May.
No. Since you are not overclocking, I'd go to the hot deals forum and look for a 2x 1GB kit from Super Talent for under $100.
Right, but you could leave the door open for OC'ing by going with that mushkin ram. Though, the kits in my earlier post would do just fine, too.
Even though I'm not overclocking, I'm not opposed to having a little overhead built in to the RAM for stability purposes.
Ok, I think I'm just about there. Unless there are any major developments, I believe this will be it.
Final comments ?
May 2007 Computer
Qty. Product Description Unit Price Savings Total Price
1 LIAN LI PC-V2000Bplus II Black Aluminum Server Computer Case - Retail
Model #: PC-V2000Bplus II
Item #: N82E16811112062
Return Policy: Standard Return Policy
In Stock
$299.99 -$20.00 Instant $279.99
1 Link Depot UV 4Pin Y Power Cable Model POW-UV-4PY - Retail
Model #: POW-UV-4PY
Item #: N82E16812189002
In Stock
$1.79 $1.79
1 Link Depot 12" 3pin UV Power Supply Extension Cable Model POW-UV-12EXT - Retail
Model #: POW-UV-12EXT
Item #: N82E16812189004
In Stock
$1.29 $1.29
1 Athena Power 4pin (P4ATX-12V Male) to 4pin (P4ATX-12V Female) Extension Cable Model Cable-AD09 - OEM
Model #: Cable-AD09
Item #: N82E16812198005
In Stock
$3.29 $3.29
1 Athena Power 12" EPS (24Pin) connector Extension Cable Model Cable-AD08 - OEM
Model #: Cable-AD08
Item #: N82E16812198007
In Stock
$5.50 $5.50
1 HIPER Cable Model HLC-3M3C-15 - Retail
Model #: HLC-3M3C-15
Item #: N82E16812335003
In Stock
$5.99 $5.99
1 Intel BOXD975XBX2KR LGA 775 Intel 975X ATX Intel Motherboard - Retail
Model #: BOXD975XBX2KR
Item #: N82E16813121059
Return Policy: Limited 30-Day Return Policy
In Stock
$249.99 -$20.00 Instant $229.99
1 EVGA 768-P2-N831-AR GeForce 8800GTX 768MB GDDR3 PCI Express x16 HDCP Video Card - Retail
Model #: 768-P2-N831-AR
Item #: N82E16814130072
Return Policy: Limited Non-Refundable 30-Day Return Policy
In Stock
Mail-in Rebate
$559.99 $559.99
1 PC Power & Cooling Silencer 750 Quad (Black) EPS12V 750W Continuous @ 40°C (825W Peak) Power Supply - Retail
Model #: Silencer 750 Quad BK
Item #: N82E16817703009
In Stock
$249.99 -$30.00 Instant $219.99
1 Intel Core 2 Duo E6600 Conroe 2.4GHz LGA 775 Processor Model BX80557E6600 - Retail
Model #: BX80557E6600
Item #: N82E16819115003
Return Policy: Processors (CPUs) Return Policy
In Stock
$308.00 $308.00
1 mushkin 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model 996527 - Retail
Model #: 996527
Item #: N82E16820146118
In Stock
Mail-in Rebate
$179.99 $179.99
1 Seagate Barracuda 7200.10 ST3500630AS 500GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
Model #: ST3500630AS
Item #: N82E16822148136
In Stock
$145.00 $145.00
Subtotal: $1,940.81
Ah, hell. It's always something...
What's a reliable brand of floppy these days?
In Stock
hehe... well, thats how I read that post, lol... and was like, REALLY?!?!? then I remembered the format of newegg's cart when c&p'd.
well, from my experience, each brand has crapped out on me, lol. i don't think fdd brand matters much. i've got all different brands in all working computers that still have a floppy. the most recent are mitsumi, since they have card readers integrated into the same drive (two of them). the media box has a sony fdd. i also have boxes using an nec fdd, as well as a samsung fdd. they all work fine until you plug the cable in backwards, lol.
Vista + 8800 = bad, bad, bad!
Get a midrange X1900 to tide you over until R600. NVIDIA's Vista support is virtually nonexistent right now, so don't even bother with the headache. Use XP, or buy a card from a reputable company.
From what I've seen in the Video Card forums the new drivers seem to fix most Vista errors, check them out for yourself.
I'm not doing SLI, so this should not be an issue. I hope :)
I have since found that they are $7 each, so who cares :) I'll buy two!
Well, we all know that sooner or later, there will be a good driver out... so you just have to be patient. I, for example, won't even be switching to Vista for at least a year, lol.
You may not be, but if the OP is building this machine specifically for Vista. Thought I'd give him a heads up that he's cruising for a bruising. :p
The problems affect non-SLIers as well.
Interesting. I had understood that a single 8800 was pretty clean with the latest drivers.
Hmmmm......
Read in the video card section they say it was doing very well since that latest drivers came out even before then it would have been the video card to buy I'm not sure where he's coming from..........
how are the Lian-Li cases for a build like this. Particularly the V2000:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811112119
Lian-Li Case = Sexy
...as far as how well everything will fit into a Lian-Li...
i had a little trouble finding the right power supply to fit into a v1000, but it was worth it. especially since that was the only negative.
I'm trying to figure out why this one is so expensive: http://www.newegg.com/Product/Product.aspx?Item=N82E16811112122 ...maybe because it comes with fans?
i think i would gladly pay the few dollars more and get the V2000...
That one looks a lot like the V1000, but with a front door.
I think I've settled on the V2000BPlus II. Nice and roomy, no real downsides.
I don't really like cases with front doors. They are always in the damned way for me and I usually end up taking them off :)
Lian-Li Case = Sexy
Just as an alternative to your Seagate 500 GB hdd, you might want to look at WD Caviar SE16 (WD5000KS). Cheaper AND faster (at least from the last review I read comparing the two).
