Sir_Poop_Alot
- Aug 2, 2008
I'm using all the 6gb/s ports for the hard drives (2x250gb in Raid0) and 2x640gb as backup. Using the 3gb/s (red sata) for the DVD drive.
sounds good sir. hope you dont run out of luck.
let us know if one of them breaks so we know if its the 6gb ports or the 3gb ports goin bad.
You be the first to know if one of them breaks
Any drivers needed for marvel ports?
Ouch, my eyes hurt. Cable management = good for u
im confused.
- so the dark blue two ports are marvell 6gbps ports. those are safe to use and are back compatible with sata 2 hard drives, but NOT sata 2 dvd drives right?
- the two white ports are 6gbps intel chipset based which are flawed. right?
- the 4 light blue ports are sata 2 intel chipset ports which are flawed as well
is this all correct?
The problem in the chipset was traced back to a transistor in the 3Gbps PLL clocking tree. The aforementioned transistor has a very thin gate oxide, which allows you to turn it on with a very low voltage. Unfortunately in this case Intel biased the transistor with too high of a voltage, resulting in higher than expected leakage current. Depending on the physical characteristics of the transistor the leakage current here can increase over time which can ultimately result in this failure on the 3Gbps ports. The fact that the 3Gbps and 6Gbps circuits have their own independent clocking trees is what ensures that this problem is limited to only ports 2 - 5 off the controller.
Ports 2-5 are the Intel 3Gbs ports.
On my Deluxe board, the bad ports are labelled 3-6.
Posted via Mobile Device
