My tech station build
EricFX1984
this tech station is actually a combo of 2 existing cases... when done it will house (4) 5 1/4 bays and between (6) and (10) 3 1/2" bays.
The Motherboard will be externally mounted with a set of hinges on the tray allowing for easy access to the internals...
it will have provisions for at least (3) 120mm fans on the bottom level
I am debating weather this should be a vertical or horizontal case...
also planning to have cmos reset provision
this is the front, I will be cutting out the marked space for a 120mm fan
I will also mount a 120mm or (2) on the top tray to aid in cooling the video card and the motherboard components
the top tray will be hinged at the back and will lock in place with the use of 2 small magnetic clasps
the rear will allows mounting for (2) more 120mm fans
I would hope it would be horizontal (make it easier to work with) but vertical idk just have to wait and see, but sure does seem interesting though.
well its almost done, just needs more paint and some edge molding
it hold 11 3 1/2 drives iirc
front
Motherboard tray opened up
back, note the 3 hard drive holder with external access
