Swiftech Storm
PolarFlo TT Acrylic gpu
77Bonn heatercore
Iwaki MD20RZT
Idle Temp: 32c
Load Temp: 40c
My only caveat with this new system is that the iwaki pump gets extremely hot. so hot that it would burn you if you left your hand on it. I put a 120 in front of it and it seems to help the situation some, but I bet my temps would be better if i had an external box.
Just thought I'd show off
