My stepping Code on my E6300??
newls1
I just recieved my E6300, and the Codes are SL9SA malay/ L627A498.........
I looked in the OCing database, and found 1 person had this stepping, but do you think it is a good one? Thank you
L627A498
= week 27
chances are better with week 27 than some of the earlier weeks like 24. But as always its luck of the draw. You could get a dud or a cherry. You never know, until you plug it in & try it.
Good luck, b/c thats half the overclocking game.
You should be fine (depending on your cooling) with a DS3 and a 2mb Conroe. I might actually swap out my E6600 for a 2mb version since the 965 seems to clock better with the lower chips.
Im using the scythe INF1000 120mm, for 60.00 dollars it better perform good :rolleyes:
